never ending problem series of my Zenbook
munlu
One of my greatest regrets is buying this laptop (Asus Zwnbook OLED 3402.ZA). I have previously posted some problems with it. If you check my previous posts you can see how unhappy I am with the screen and heating issues etc. And as I use, I keep experienceing new problems. Here are some I discovered lately:
Sometimes the screen goes off itself and does not come back whatever you do. Only a reset solves it.
Sometimes this pc cannot wake up from sleep state. Only a reset solves it.
New problem added : Power button stucks at first start after opening the laptop.
I have a freshly installed and updated windows 11 with all latest drivers downloaded from the asus' website and installed. The only thing I am doing is browsing with google chrome with a few tabs open. I have only bitdefender av running in background.
11 REPLIES 11
This issue requires using your warrenty.
I had the same issue, i can send you videos of the touchpad i had (worse than you write here). Its probably a loose screw that prevents the touchpad surface to be clickable.
I have the UX5400ZB and its not that great at all.
munlu
BTW, did I mention that this machine gets hotter than my toaster with a few tabs with chrome.
