Grey lines and green flicker on webcam when using AC power
Quarter
System: Windows 10
Battery or AC: AC
Description: Grey lines and green flicker on webcam when using AC power
Model: UX533FD
Frequency of Occurrence: Always
Reset OS: No
Last edited by Quarter on 2019/12/9 09:37 As described above, the webcam image has grey lines and occasional green flickers. This only occurs when AC power is plugged in, everything works perfectly when using battery. I have removed and re-installed drivers with no success. This is a brand new laptop that I removed from the box yesterday. I see that there are two other questions with the same issue, but no answer has been provided. Is this a hardware issue and do I need to return my laptop or is there a software fix?
294 REPLIES 294
Blake_ASUS
Community Legend II
Michael_626
Hi @Blake_ASUS
I am having the same camera flickering issue with my Vivobook. How can I get the updated BIOS to fix it?
Please specify your model.
Blake_ASUS
Community Legend II
gtr525
Hey @Blake_ASUS i also have the same problem using a Q536FH and I have BIOS 306 and updated all the drivers. I use an external HP webcam and flickers when on AC only. I tried changing all those power settings. Any ideas?
do you mean Q536FD?
Hey @Blake_ASUS i also have a similar problem with ASUS Vivobook S14 x430FN with BIOS 308. Any advice?
Isabell
Hi there,
Also experiencing the same issue with the grey and green flicker while using webcam. Any advice?
Blake_ASUS
Community Legend II
Isabell
Hi there,
