Battery problem
Sirbangs1209
System: ux325e
Battery or AC:
Model:
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:so my battery is not charging I plug it in and it turns on then says battery is low and dies. Wondering what steps I should take 1st can not get to windows before it dies thanks
Falcon_ASUS
Sirbangs1209
  1. System: ux325e
  2. Battery or AC:
  3. Model:
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
Battery problem
@Sirbangs1209
Please refer to the following FAQ for troubleshooting.
[Notebook] Troubleshooting - How to fix the battery cannot provide power/be charged, or be fully cha...If the situation remains the same, according to what you described, please contact ASUS repair center in the country of your residence: https://www.asus.com/support/Service-Center-All-Countries/.
ASUS_Bot
Rising Star II
