Asus ZenBook Pro 14 OLED UX6404VI and Asus VivoBook Pro 16X 3D OLED K6604JI
Shay_Hulud
Hello,
I see that both laptops are equipped with RTX 4070 but there is no mention of their power. Can you please tell us TGP for these models?
Thak you!
noteb.com team
1 ACCEPTED SOLUTION
Accepted Solutions
@Shay_Hulud
After reconfirmation, the relevant information is as follows.
UX6404VI -> 110W
K6604JI -> 130W
5 REPLIES 5
Shay_Hulud
Thank you for answering @Falcon_ASUS but every manufacturer limits the power used by the GPU, and they usually list it. I highly doubt that the RTX 4070 from Zenbooks reach 150W when the ones from ASUS ROG are limited to 120W or 140W. A good example is this one: https://rog.asus.com/laptops/rog-zephyrus/rog-zephyrus-duo-16-2023-series/spec/
By the way, there is a mention on the NVidia site: "Performance will vary by laptop model; check with the manufacturer for their particular model and specifications" - they are talking about the power limit here, that's why I asked here. I don't know where else to ask, this information should have been listed...
Hope you manage to find my answers, thank you for your time.
noteb.com team
@Shay_Hulud
UX6404VI -> 110W
K6604JI -> 130W
Excellent!
Thank you for your time and patience!
ula
last week I bougt xenbook 14 oled and I`m using it for a week and it`s heating. I mean on computer has really bad overheating. how can fix this
