ASUS Quick Keys and Control Panel don’t work with Figma
C_Teodor
I have the new ASUS Zenbook Duo with two touchscreens and when I work with Figma I use the second display for the ASUS Control Panel shortcut keys. These are mapped to different functions in Figma, but most of them do not work (ex. Swap fill and Stroke [Shift + X]). The same problem with the Asus Quick Key App. Is this a problem with Figma or the Asus apps? I tested these Quick Keys and Control Panel shortcuts in other apps (such as VSCode) and they work. Thank you for your support!Screenshot 2024-05-16 213459.png
6 REPLIES 6
Thank you for your response! I already performed this process according to your advice and it still didn't work, but then unexpectedly found the solution: it was the keyboard layout setting in Figma. Mine was set on U.K. (PC) and when I switched to "generic" it worked perfectly fine.
@C_Teodor
Understood.
Since the keyboard we tested is a generic keyboard, it's possible that the error occurred due to different keyboard configurations.
Thank you for sharing this information.
