Battery mode
D_IMAN
Rising Star II
If you open Settings/System/Power & Battery - there is an item "Battery Mode"
1. Maximum energy efficiency
2.Balance
3. Maximum performance.
Do these models really work?
Why aren't they under the Power tab in Control Panel?
Laptop model: N7400PC (X7400PC)
BIOS version 303
ASUS System Control Interface v3 V3.1.18.0
Falcon_ASUS
@D_IMAN
This is data provided for your reference, and if you have concerns about the system's design options, I suggest you can provide feedback to Microsoft.
https://support.microsoft.com/en-US/contactus
It’s strange, if these circuits don’t work, then why place them there?
And it seems to me that they appeared there after installing the drivers for my model.
