E410MA lap top wont stay on unless plugged in
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-21-2025 12:57 PM
ASUS Lap top wont stay on unless it is plugged into mans. Battery is fully charged and immediately goes off as soon as the cable is removed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-21-2025 05:14 PM
@ianrichardson
We recommend referring to the following FAQ to use the MyASUS app for a battery check.
Troubleshooting - Device’s Battery not supplying power/charging, Battery not charging to full, Unabl...
If the check fails, it is likely that the battery is faulty. In that case, we suggest taking your laptop to a service center for further inspection.
