How to connect X571GT to a gaming monitor and get higher resolution
Knotist
System: Windows 10
Battery or AC: Ac
Model: x571gt
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
Hey,
I just bought a new Samsung monitor that has 144 hz refresh rate and 2k resolution. It has 2 HDMI and 1 DP ports.
My laptop got only 1 HDMI port. And I don't know how much bandwidth can it send to the monitor. I can't find any info about the HDMI port version of my laptop.
I bought a nice HDMI cable which supports 48 gbps. Even with it my monitor shows 60 fps max in 2k. I'm sure it supports 120 hz on HDMI ports.
So my question is is there any way to connect my laptop to my monitor and get 120 hz at least. Or maybe if I buy an active HDMI to DP converter and use monitor DP?
Since Nvidia only supports G Sync on Display Port it's so weird that my laptop does not comes with a DP output.
5 REPLIES 5
RAJU_MSC_MATHEM
Zen Master I
Knotist
  1. System: Windows 10
  2. Battery or AC: Ac
  3. Model: x571gt
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
Hey,
120hz depends upon the chipset of the motherboard , hdmi port version , compatible hdmi driver , properties of graphics card in laptop
Knotist
How can I make sure if my laptop supports? I can't find any information about it on any website.
RAJU_MSC_MATHEM
Zen Master I
Knotist
If you the know the processor model with Ghz, then we can find the chipset features on the intel website
https://www.intel.com/content/www/us/en/products/overview.html
Blake_ASUS
Community Legend II
Hello Knotist,
X571GT 's HDMI port is HDMI1.4
