07-21-2022 02:06 PM
07-21-2022 07:57 PM
nathanmoreland4@nathanmoreland4
- System: Windows 11
- Battery or AC: n/a
- Model: Vivobook 16 x M7600
- Frequency of occurrence: always
- Reset OS: Windows 11
- Screenshot or video: desc
Detailed description:
The fingerprint sensor (in the power button) has worked in the past. Now, when I try to log in it gives me the option to use the fingerprint sensor but touching the sensor does nothing. I removed my fingerprint in settings and tried to add it again but could not get through the setup as touching the fingerprint sensor does nothing. I then removed the fingerprint sensor drivers and restarted. Once restarted windows automatically reinstalled them but the problem persisted. Eventually, I reinstalled windows entirely but that did not work either. The laptop is a couple of days old. Windows detects the fingerprint sensor but the sensor does not respond to touch.
Thank you
incase confirmation is needed that a fingerprint sensor does actually exist on the device...
Fingerprint sensor not working Vivobook 16x
08-18-2022 02:14 AM
09-17-2022 11:15 AM
