Define two pre-set settings for plugged in and on battery state of the laptop
Ali_NEX
System: Windows 11 home
Model: Vivobook 14x
Detailed description:Hello,
I was wondering if there's a way to define two preset states for my laptop when it's plugged in and for when it's not. I want the system to automatically go for 60hz with a lower resolution when on battery and then switch back to 90hz and a higher resolution when plugged in. Is there any way to do that without having to go to settings and do it manually every time?
Thanks,
1 ACCEPTED SOLUTION
Accepted Solutions
Falcon_ASUS
Ali_NEX
  1. System: Windows 11 home
  2. Model: Vivobook 14x
Thanks,
@Ali_NEX
Unfortunately, as far as I know, it should be set manually.
Falcon_ASUS
Ali_NEX
Thanks,
@Ali_NEX
ASUS_Bot
Rising Star II
