Define two pre-set settings for plugged in and on battery state of the laptop
Ali_NEXAli_NEX Level 1
edited November 12 in VivoBook
  1. System: Windows 11 home
  2. Model: Vivobook 14x
Detailed description:Hello,
I was wondering if there's a way to define two preset states for my laptop when it's plugged in and for when it's not. I want the system to automatically go for 60hz with a lower resolution when on battery and then switch back to 90hz and a higher resolution when plugged in. Is there any way to do that without having to go to settings and do it manually every time?
Thanks,
Best Answer
Comments
  • Thread automatically closed due to inactivity. If the reported issue has not been resolved or you require further assistance from one of our moderators, please create a new thread and we will be with you shortly.
