Connect external monitor via USB-C?
athena1710
System: Windows 10
Battery or AC: AC
Model: Asus VivoBook X532FLC_S532FL
Frequency of occurrence: Always
Reset OS: Yes
Screenshot or video: N/A
Detailed description:
Good afternoon. I bought a USB-C to DP cable with which I hoped to connect an external monitor; however, it does not detect the monitor when connected. The cable itself advertises itself as suitable for devices with "DisplayPort alternative mode". Does my laptop support? Thank you.
Blake_ASUS
Community Legend II
Hello athena1710,
The USB C port on this model does not support display export.
hersegu
I have the same question with vivobook S433FA-PRO-EB073R.
Regards,
Guy.
Blake_ASUS
Community Legend II
hersegu
Regards,
Guy.
Hello Guy,
The USB C port of your model does not support display export.
