10-06-2020
04:05 AM
- last edited on
01-16-2024
12:37 AM
by
ZenBot
10-09-2020 01:33 PM
10-10-2020 10:01 AM
rgilbert07I suspect that battery circuit , gold slide plates are not properly , connected to laptop slot.Can nobody tell me if this machine should run without a battery or how to charge the battery out of the laptop?
10-10-2020 11:25 AM
10-10-2020 11:33 AM
rgilbert07You are electronics engineer, so I can't say anything.I'm a retired radio and electronics engineer and have had the motherboard out to check for dry joints at the battery connectors, found none. In fact all the soldered joints on the motherboard appear fine. Checking the voltages at the battery connector shows that the motherboard doesn't appear to be supplying power to the battery although there is power at the supply socket.
As it won't boot, due to the flat battery, I can't type any command......
Should it be possible for it to run solely from the external supply or does it need to have a battery there? Any chance of finding a circuit diagram anywhere?
