A540L battery not charging, laptop now won't power up
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-06-2020
04:05 AM
- last edited on
01-16-2024
12:37 AM
by
ZenBot
System: Windows 10
Battery or AC: Both
Model: A540L
Frequency of occurrence: Permanent
Reset OS:
Screenshot or video:
Detailed description:My wife's A540L stopped charging the battery but would run on the external supply. Checked the external supply and power all good. Battery appeared to be totally discharged so concluded it had probably died so bought a brand new replacement. Fitted that and the system reported the battery to be 45% charged, plugged in and 1 hour 45 mins to full charge. However, the battery didn't charge so tried some online solutions, such as battery out, power disconnected, power button held down for 60 seconds, uninstall and re-install battery drivers, etc. Nothing made any difference the the battery progressively dropped until it showed 0% and the laptop shut down. Now it won't start and does not acknowledge the supply being plugged in.
Is this correct? On most laptops they will run on the external supply without a battery but this seems to need a battery with some power in it to run? As the laptop doesn't charge the battery, is there any way I can charge the battery out of the laptop so I can at least get it to run for a while to get the data off the hard drive? As the laptop is only ever used indoors, it is an option to run it permanently from the external supply, can it be forced to do this by linking pins on the battery connector? Or do I just pull the hard drive and buy another laptop?
Battery or AC: Both
Model: A540L
Reset OS:
8 REPLIES 8
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-10-2020 01:33 PM
That's exactly what I'm talking about. Every laptop I have ever owned or used, IBM, Lenovo, Fujitsu, Dell, Toshiba, Advent, MSI and various others will all run from the external supply with no battery fitted. I've often removed one battery when fully charged and fitted another to charge it without powering the laptop off. Maybe because they have all had removable batteries but this Asus has an internal, non-removable, battery. Not without opening the machine up anyway, but it uses the same battery connections, it just isn't supposed to be user accessible. I would still expect it to run with the battery disconnected, it's no different to having a fully discharged battery surely?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-11-2020 07:44 PM
Hello rgilbert07,
Please kindly send your device to service center for a complete examination.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-12-2020 03:38 AM
It's about 4 years old so no longer under warranty and isn't worth spending money on it. It's only a low spec, entry level, laptop that was barely capable of running Windows 10, even though that's what it came loaded with. As nobody has been able to answer my questions, like, should it be possible to run without a battery installed, how can I charge the battery out of the machine and can I get a circuit diagram for it so I can test the charging circuit myself, I'll be pulling the SSD I installed rather than the pathetically slow 5,400 rpm hard drive it came with originally and putting it in the dustbin.
I've come to the conclusion that rather than buying a new, cheap laptop it's far better to spend the same amount of money on a second hand, high spec, well built laptop.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-15-2020 03:20 AM
As the question hasn't been answered and it seems nobody on here actually understands the hardware, the A540L has now been replaced. For the same money as a brand new, entry level, low spec laptop, it's been replaced with a 4 year old, ex corporate, Lenovo W540. i7 processor, 16Gb RAM, Nvidia graphics, 15.6" full HD display, DVD re-writer and a 500Gb SSD. Blindingly fast, built like a battleship (Carbon Fibre chassis) so no flexing and twisting of the base or screen and , best of all, didn't come loaded with bloatware, 30 day free trials of software I'll never use or added 'bonuses' that manufacturers seem to think we all want, just an empty SSD all ready for a nice clean install of Win 10.
Sorry Asus, but it's goodbye from me.
- « Previous
- 1
- 2
- Next »
