Power supplied dock for vivobook
caineknight1
needing to know which dock I can use to connect my laptop to a monitor and speaker setup when I'm t home? Would like it to have independent power supply so I can keep the existing charger mobile for when I travel.
Falcon_ASUS
@caineknight1
I would recommend that you first confirm the model of the laptop you are using and whether it has any ports that allow image transmission through a dock. Since there are many brands of docks available on the market, I suggest referring to relevant reviews before making a purchase. Thank you.
