Battery very slowly discharging while Maximum Lifespan Mode is enabled, is this normal?
destel
System: Microsoft Windows 11 Pro 64-bit 10.0.22000
Model: Asus Vivobook Pro 15 OLED M3500QA
Detailed description:
Hello.
I am unfamiliar with how MyAsus Battery Health Charging options work exactly. I'm on a brand new laptop.
I would like to have my laptop plugged in most of the time, while also maintaining the internal battery's health. Thus, I assumed that the Maximum Lifespan Mode (charging up to 60%) was correct for this type of usage.
I enabled this mode when the battery was already charged to 80% and I plugged in the AC. Since then and after shutting the laptop down for 8-10 hours, the battery percentage has been declining very slowly and is now at 73%.
Is this discharging to be expected when the battery is above 60%, the Maximum Lifespan Mode is enabled and the laptop is plugged in?
Can this discharging or the use of Maximum Lifespan Mode when the battery is above 60% harm the battery?
Thank you very much.
1 ACCEPTED SOLUTION
Accepted Solutions
Falcon_ASUS
destel
https://zentalk.asus.com/en/discussion/comment/223350#Comment_223350
What is the BIOS version and system version you are currently using?
BIOS version: 304
GOP version: 2.16.0.17.10
EC version: F0072206306
Could you please provide me with a picture of the power settings for me to confirm?
Current settings.
About this description : Since then and after shutting the laptop down for 8-10 hours, the battery percentage has been declining very slowly and is now at 73%.
Does the same thing happen every time you turn off the laptop?
For the last 24 hours my Power Plan was the ASUS Recommended.
I enabled Maximum Lifespan Mode on August 14 when the battery was charged up to 80% and I also plugged in the AC adapter. As you can see from the graph the battery had been very gradually discharging, while plugged in.
When I turned on the laptop both yesterday and today, after it had been turned off for circa 8 hours, the battery had drained a little. After powering on the laptop today, it had gone down by 1% and was at 72%.
I just switched to the Balanced power plan. After changing the Power Plan, the battery is now at 75%.
No inconvenience, I just want to make sure that nothing is wrong with my battery or my settings. I have never used software to limit battery charging, so I don't know how they work or how reliable/safe they are.
@destel
The BIOS you are using is not the latest version, please update the BIOS to the version 308.
[Notebook] How to update BIOS in Windows | Official Support | ASUS GlobalAnd please also update the system to the latest through Windows Update.
[Windows 11/10] Windows Update | Official Support | ASUS Global
Back to your original question.
If you enabled the Maximum Lifespan Mode (charging up to 60%), the battery will only be charged to 60%.
When you shut down the laptop and the battery is more than 60% charged, it will slowly drop to 60%.
Since you mentioned that the battery was charged to 80%, could you please help me to confirm, when this mode is enabled, will the battery charge above 60%? Or, it's 80% charged because you've turned on balance mode.
And based on the information you provide later, If you are currently set to balance mode, the battery performance appears to be normal.
7 REPLIES 7
RAJU_MSC_MATHEM
Zen Master I
open command prompt with admin rights and copy and paste below line , press enter
PowerCfg.exe /BATTERYREPORT -output C:\Battery_Report15-08-2022.html /duration 14
wait for five to complete, share the report
destel
RAJU.MSC.MATHEMATICS
Hi, thank you for replying.
I went to the Windows command line documentation. Does /duration 14 mean that I have to wait an extra 14 days or is this a report for the last 14 days?
I've only got this laptop for 3 days, so I could skip the /duration argument, right?
Would this command work instead?
powercfg /batteryreport /output "C:\Battery_Report15-08-2022.html"
Falcon_ASUS
destel
  1. System: Microsoft Windows 11 Pro 64-bit 10.0.22000
  2. Model: Asus Vivobook Pro 15 OLED M3500QA
Hello.
@destel
destel
Falcon_ASUS
https://zentalk.asus.com/en/discussion/62937/battery-very-slowly-discharging-while-maximum-lifespan-...
@destel
BIOS version: 304
Current settings.
