Asus TP3402 - Battery drain problem during shutdown and hibernate.
grgczyz
Dear Asus,
In my previous posts I mentioned that I have a problem with battery drain during shutdown.
In the meantime I read a little about it and discovered nice tool in Windows - sleepstudy report. Thanks to this tool i could check battery drain problem even better.
I prepared 2 tests for shutdown and hibernate:
As you can see in both cases battery drain is about 5% per 12 hours (10% per 24hours)
I also tried "plane mode" and there was nothing in usb ports.
I also tried with switched off "modern standby" but did not help.
I have fastboot switched off (both in windows and bios) - does not affect on the problem.
All drivers and bios are updated.
What is this "UNKNOWN [NONE]: APP ID ? How to find it and disable it?
What is this "OTHER [mW]" - some loses? What kind?
Is there s.th. else I can do myself to solve this problem or the laptop is definitely broken and requires a visit in service?
Best regards,
Greg
5 REPLIES 5
ZenBot
Community Manager
Community Manager
