solution for cod mobile (lag and freeze)
joschi_b850
solution hello, i sat down yesterday to solve the problem with the rog. I looked at the values ​​and created a separate scenario profile for cod. I adjusted some values ​​there. In the last 10 games I have great scores and no more problems. I hope it helps you too. video below
comment if it helped you
22 REPLIES 22
joschi_b850
give the contribution times a thumbs up. a thumbs up is somewhat little:D
joschi_b850
joschi_b850
Hello, community,
New update new problems and that is what a luck not only for us ROG users.
Since the new update to Android 10, there is currently the problem that in BR mode a black screen appears once per round.
After the current post from Activision there will be a fix in the near future which should solve this problem - we are curious.
Since we don't want to wait that long, there is a solution that will allow us to play without any failure.
****Solution****
in advance you can still use the profile that was posted above.
1: You have to go back to Android 9 (takes only 5 minutes)
Make a backup via Google Drive before you reset to 9.
1.1 Download the official dorngrade version on Android 9 P from the Asus site
1.2 After downloading the ZIP file, connect your ROG to your computer and open your mobile phone folder
1.3 Copies the file into the folder ( Attention: Do not copy into any other folder )
1.4 Restart your phone, you will now get a message that a new update is available.
Downgrade and you are back on Android 9 P
**** Setting in COD Mobile****
You can find a picture in the appendix. You are welcome to try out the COD settings and tell us about them.
See you on the battlefield 😉
P.s sorry for my broken english 😄
