solution for cod mobile (lag and freeze)
joschi_b850
solution hello, i sat down yesterday to solve the problem with the rog. I looked at the values ​​and created a separate scenario profile for cod. I adjusted some values ​​there. In the last 10 games I have great scores and no more problems. I hope it helps you too. video below
comment if it helped you
22 REPLIES 22
joschi_b850
Apollofury
Rising Star II
joschi.b850
https://us.v-cdn.net/6031231/uploads/823/1PBQLB9GIW0K.mp4
just inputted the values , gonna start testing . As advice on temperature control ? should be low , default or high?
sagarreddysag
Rising Star II
joschi.b850
Idk if it works or not but nice work . Anyway i am not a COD player only pubG nerd.
Apollofury
Rising Star II
ApolloFury
https://zentalk.asus.com/en/discussion/comment/39260#Comment_39260
Just played COD for around an hour with battle royal mode ( most lagging and freezing happens in BR mode) , until now there is no freezing but there is slight lag. With play for a few days and update on the issue but looks like it just might work!
@joschi.b850 bro if it works then you should become part of the ROG Devs !! ? cause we have been complaining for so long and there no solution until now
