solution for cod mobile (lag and freeze)
joschi_b850
solution hello, i sat down yesterday to solve the problem with the rog. I looked at the values ​​and created a separate scenario profile for cod. I adjusted some values ​​there. In the last 10 games I have great scores and no more problems. I hope it helps you too. video below
comment if it helped you
22 REPLIES 22
joschi_b850
ApolloFury
https://zentalk.asus.com/en/discussion/comment/39280#Comment_39280
Just played COD for around an hour with battle royal mode ( most lagging and freezing happens in BR mode) , until now there is no freezing but there is slight lag. With play for a few days and update on the issue but looks like it just might work!
@joschi.b850 bro if it works then you should become part of the ROG Devs !! ? cause we have been complaining for so long and there no solution until now
hey, yes great to hear that it worked so far. which network are you connected to? mobile network or via Welan?
the question is whether the men have even dealt with the topic Thema.
Aryan202
Community Legend I
I've said this multiple times
This is a issue on Tencent's server side
It's a global issue which affects all phones(I've myself seen it on different phones)
Just search up cod on PlayStore you'll see many negative reviews from people reporting the same (that's the reason the game's rating has gone down a bit overall)
Asus can't do anything to "fix" it
Asus isn't liable for anything that happens "inside" your game
joschi_b850
@Averan I can't promise that. I used the iphone as an alternative. the problem is not known to the clan and the large Facebook groups, but here and there it wasn't that extreme.
adjust the rating in the playstore so that you only see the one that uses your hardware. with the settings shown above, it is completely playable to compare the standard settings of the rog.
if you have any further problems just comment under the post☺️
best greetings from Germany
Apollofury
Rising Star II
joschi.b850
https://zentalk.asus.com/en/discussion/comment/39324#Comment_39324
I used 130 Mbps wifi connection and also my mobile network airtel
Mace
joschi.b850
https://us.v-cdn.net/6031231/uploads/230/XC07XQN2WPPZ.mp4
Thx Form this. My Problem ist solved
