does not catch wifi networks
pavelpodryadchi
Sorry that in Russian.
The problem is that after the game there was an interruption of the wi fi network and after that it can not find more than one wifi net
work
22 REPLIES 22
ronald1985
Community Legend I
pavelpodryadchik
https://zentalk.asus.com/en/discussion/comment/93363#Comment_93363
You misunderstood me. I said that I was flashing RAW 9 and trying to flush RAW 10 was useless. My phone "tencent games" is not global, so there is no guarantee. I myself was looking for a solution in foreign forums, I thought that the problem was still software, but it turned out that there was still no way I would go now to create a topic on the XDA. thanks for the help
data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAAngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZ...
Did Wifi work for you before?
pavelpodryadchi
ronald1985
https://zentalk.asus.com/en/discussion/comment/93480#Comment_93480
Yes, of course, it stopped working after I played in the world of tanks blitz most likely there was overheating. And so from the reviews, I realized that asus has a lot of marriage although I do not have a global version of the smartphone
ronald1985
Community Legend I
pavelpodryadchik
https://zentalk.asus.com/en/discussion/comment/93532#Comment_93532
Thanks - I would probably recommend taking your phone to a service centre. The test you did showed there was problems with WIFI.
Remember to not do it yourself as you would void your warranty.
Good luck my friend.
