does not catch wifi networks
pavelpodryadchi
Sorry that in Russian.
The problem is that after the game there was an interruption of the wi fi network and after that it can not find more than one wifi net
work
22 REPLIES 22
pavelpodryadchi
worked stably for a week and then stopped finding networks
ronald1985
Community Legend I
pavelpodryadchik
https://zentalk.asus.com/en/discussion/comment/93042#Comment_93042
Wifi status
Wifi config
How did you get to the above screens? I was going to compare against what I have but I can't find any menus that look like yours.
pavelpodryadchi
ronald1985
https://zentalk.asus.com/en/discussion/comment/93051#Comment_93051
*#*#4636#*#*
ronald1985
Community Legend I
pavelpodryadchik
https://zentalk.asus.com/en/discussion/comment/93052#Comment_93052
*#*#4636#*#*
Thanks! Mine is the same but with different WIFIs I have been on.
Has this ever worked for you or did it fail after upgrading?
I do have one or two more suggestions, but it is ironic though and you probably don't want to do it which is fine too.
The first one is to go to the Calculator and type in .12345+=, go to Single Test and then WIFI Test. Do let us know whether it passes or fails.
The second one, use an app from play store to see if it detects any WiFi networks.
The very last resort because you have switched between Android 9 and 10, do a factory reset on the whole device. But I would wait for more people to help you on this.
pavelpodryadchi
ronald1985
https://zentalk.asus.com/en/discussion/comment/93055#Comment_93055
thanks, as they say. Trying is not torture, demand is not a problem
