does not catch wifi networks
pavelpodryadchi
Sorry that in Russian.
The problem is that after the game there was an interruption of the wi fi network and after that it can not find more than one wifi net
work
22 REPLIES 22
ronald1985
Community Legend I
pavelpodryadchik
https://zentalk.asus.com/en/discussion/comment/93035#Comment_93035
from other devices I can connect to wifi, I'm not a fool to bother people in vain in vain, I tried to even change the version of android, switched to 9 and then turned back to 10; installing raw firmware does not help
One more thing to try is go to add network manually and start putting in the WIFI information to see if it finds it. The idea here is to show that your network is not hidden.
pavelpodryadchi
ronald1985
https://zentalk.asus.com/en/discussion/comment/93037#Comment_93037
also did not help
pavelpodryadchi
at the same time, the access point for distributing wifi also does not work, other phones do not see it and also try to manually enter and use the QR code
ronald1985
Community Legend I
pavelpodryadchik
Thanks for your time @pavelpodryadchik.
Sorry if I misunderstood but for clarity, can other phones connect to the same WIFI as you're trying to connect to now?
pavelpodryadchi
ronald1985
https://zentalk.asus.com/en/discussion/comment/93041#Comment_93041
Yes they can
