07-30-2021 04:05 PM
08-04-2021 02:20 AM
ARP_ASUSThe speed on 2.4 ghz channel is appropriate, problem is with the 5ghz channel.Hi krnapj,
There could be a variety of reasons here.
I have tested on iPad 6th gen and ROG Phone 5 as well
3 test - All tests are in the same range of 8mbps - 11mbps download speed
Can you try changing the channel, using a different Wifi. The difference for you as I see in 200mbps
You can use a spare phone to create a hotspot and test it out.
08-05-2021 06:00 AM
08-05-2021 02:40 PM
FunBike31It's nokia G-140W-F, I don't know how to deactivate ipv6 , there is this option I can find in router settings ( in the ss) but it is blocked .Hello,
- You tried to test with different servers
- You have verified that there is no bandwidth limitation configured on your wifi router
- You can also try IP v6 deactivation on your Wifi router
If this does not bother you, indicate the name and model of your wifi router, if there is an incompatibility or not with mobile phones this will help to confirm the problem or to troubleshoot it.
08-05-2021 06:55 PM
08-05-2021 07:21 PM
