Asus ROG 8 Pro Slow Wifi 7 slow transmission speed
Koudmaker
Zen Master I
i found a weird bug on low transmit speed while being connected to a Wifi 7 access point with 2.4 and 6Ghz connected. Normal it should be around 5000+ MBps but after some time it dropped crazy to 688mb like its only connected to 2.4ghz connection and will cause a crazy delay.
The phone is connected on a MLO network with 2.4, 5 and 6Ghz enabled.
Mesh system Model TP-Link BE19000 (Deco BE85)
Koudmaker
Zen Master I
Its a problem with the phone because all other devices i don't have the slow bandwidth problem.
thomasjohn123
This issue might be due to the ROG Phone 8 switching bands within the MLO (Multi-Link Operation) network. Some devices can have trouble balancing connections across 2.4, 5, and 6 GHz on mesh systems, especially with TP-Link BE19000’s firmware. Try these steps:
  1. Update Firmware: Ensure both your ROG Phone 8 and Deco BE85 are on the latest firmware.
  2. Disable or Limit MLO: Temporarily turn off MLO or limit the 2.4 GHz band to see if speeds stabilize on 5 or 6 GHz.
  3. Check Network Settings: Within the Deco app, prioritize higher frequency bands for low latency and higher throughput on supported devices.
If the issue persists, it might be worth contacting TP-Link for specific firmware optimization, as multi-band coordination on Wi-Fi 7 is still maturing.
For More Information You can visit: https://quickgrade.us/
