What power adapter is compatible with my Proart W5600Q2A?
Valshnar
I was using non-asus docks and am trying to spend money at ASUS to get my system working smoothly.
The ASUS SimPro 2 dock I just bought can't power my PC reliably - it keeps behaving as if i've unplugged and re-plugged my power...maddening.
So fine, I'll buy a power adapter.  The biggest and best, right?  Which ones are compatible?  I've spent 20 minutes on the site and can get no clue as to which are and are not compatible.  That's stupid.
My company decided to try an ASUS instead of the usual HP or Dell and while I like the computer stuff like this gets in the way of success.  That and the fact that it can't be registered...
Falcon_ASUS
@Valshnar
The AC adapter secifications for W5600Q2A are as follows.
Power Supply : ø6.0, 240W AC Adapter, Output: 20V DC, 12A, 240W, Input: 100~240V AC 50/60Hz universal
SimPro Dock 2 is not compatible with W5600Q2A, its support list is as follows.
ASUS SimPro Dock 2 Compatible Model List
ZenBot
Community Manager
Community Manager
