Zenbook Pro 14, dock and Solidworks
Tropazoy
Hello!
At the brink of buying but need to verify:
I would like to know if the Simpro Dock 2 is compatible with the Zenbook Pro 14.
My setup is two QHD screens and USB-C charging via the Docking station is a must. (so adapter can stay in the bag!)
Can someone tell me if this is possible, I could not verify this through the product information of the Simpro Dock 2, maybe because the Zenbook is relatively new?
Furthermore, the hardware I think should be sufficient for Solidworks, but there is no certification (yet?).
Specs:
Intel Core i9
32 GB
1000 GB SSD
Nvidia GeForce RTX 4060
Any advice would be greatly appreciated, thanks in advance.
Roy
Falcon_ASUS
@Tropazoy
Unfortunately, the Simpro Dock 2 is not compatible with the Zenbook laptop you are considering for purchase. It is primarily designed for compatibility with commercial laptops. Below is the list of supported devices.
ASUS SimPro Dock 2 Compatible Model List
Regarding the use of Solidworks, if you confirm that the laptop's hardware specifications meet the software requirements, then there should be no issues in its execution. Thank you.
