Rog Flow X16 mini-led screen issue
Wilsooooon
Does anyone’s X16 face the isssue of uneven colour when dimming the brightness dot below 20% ?
I just bought the X16 and not sure is that normal for all mini-led.
6 REPLIES 6
Falcon_ASUS
Wilsooooon
@Wilsooooon
I have forwarded the information to the relevant department. We will keep you updated and your consideration will be very much appreciated.
korenelszabo
Did you receive any updates?
I'm facing the same issue
Falcon_ASUS
korenelszabo
@korenelszabo
We are still confirming. I have sent you a message, please check.
rensvv
@Falcon_ASUS I am facing the same issue on my brand new Flow X16. I have included a video of the worst situation. As you can see it is pretty bad and not really useable in this state.
