Huion Graphics Tablet not working anytime- both tablet and usb port are okay.
r1t0_
System: Windows 11, Pop OS 21.04 (Dual boot)
Battery or AC: both
Model: ASUS TUF Dash F15 FX516PE_FX516
Frequency of occurrence: every time, always
Reset OS: linux one twice, Windows upgraded to 11 from 10
Screenshot or video: attached
Detailed description:
I have a graphics tablet- Huion H640P. I can use it without any issues on my android device, and tested it on two other machines- a desktop with Windows 10, and a laptop with Linux Mint (latest). The laptop is HP G7. It works on every places without any issues.
But it does not work on my ASUS device- no matter which OS I use.
I connect the tablet to my laptop, the light on the tablet goes on, and then turns off by itself. And the device is not once recognized.
I tried many fixes both on Windows and Pop, and I cannot get the tablet to work with the laptop.
All the USB ports are fine and are working without any issues.
I have tried-
Uninstalling and installing the USB drivers manually in Windows.
Shutting down, keeping the laptop off for a few minutes, then turning on with the tablet plugged in in Linux, in case if it's a power issue.
Fiddling with auto-suspension settings on usbcore on /etc/modprobe.d folder.
Nothing ever worked, the tablet does not work with my ASUS laptop and that's it.
Windows 11 has the Huion drivers installed, and the Linux has open source drivers installed. With these installed in other machines, the tablet works.
I want it very badly for the tablet to work with my new laptop.😓
7 REPLIES 7
r1t0_
Hi @Blake_ASUS , any updates? I need my graphics tablet badly.
I would even consider buying a new tablet from an E-comm site, but they do not offer Returns for graphics tablet. So, I am not sure, even buying a new tablet will solve my problems.
As I don't know whether it will work with my laptop.
Please help me use my existing tablet with my laptop.
Blake_ASUS
Community Legend II
Hi there,
This is somehow a compatibility issue that we are not able to help much.
You can consider to check on the setting in device manager, please refer to below picture.
or try another cable.
If still not working, you might need to contact Huion for this.
Sorry for the inconvenience caused. Thank you.
r1t0_
Blake_ASUS
Hi there,
I contacted Huion first, and they were not able to help. They just said, "you can't have multiple OSs". And inferred that my dual boot is causing this. The person did not seem much technical either. All they said was to download the latest driver which I already had.
I will try what you are suggesting when I am logged into Windows 11.
Can you provide me the information if any other graphics tablet of the same length will work with it? Especially if it is from XP-Pen or Wacom? Then I can buy that.
I can buy a new tablet without any problems, but I am not doing so because the new one might face the same problem, and my money will be wasted since Amazon or Flipkart does not have a return policy for those products.
If you can give me even one solid example of a tablet working with my specific model of laptop, I will buy that and consider my problem solved.
