GPU Stuck in Eco GPU Mode while GPU Mode Panel has vanished
Roasiac
System: Asus ROG Strix Scar 17
Battery or AC: Adapter (I dont know what AC stands for)
Model: G732LXS.313
Frequency of occurrence: It just happened for the fist time
Reset OS: Did not work
Detailed description:
I have been using the Mux Switch on my laptop for a while now and when Armory Crate updated to its new name GPU mode everything has been fine.
But last week my 49 inch gaming monitor fell on the laptop which was closed and after a technical checkup within my warranty I got reports back that nothing got damaged.
Today I had to do an update for Armory Crate to get it updated to version 5.3.4 while I was running 5.3.3 and while that was busy I had to do an update for my Windows as well since a new version of Windows was available which was version Windows 11 Home 22H2.
After I restarted the laptop to apply the windows update the GPU mode disappeared on the Armory Crate but what made it worse is that I had my Eco Mode turned on by default which is still turned on.
Now when I try to play games the games run on my integrated Intel gpu instead of the discrete Gen 3 RTX 2080 Super 8GB GDDR6.
I have tried looking up the update at first and noticed people getting things fixed when they rebooted their PCs which did not work for me.
So then I did reinstall Armory Crate which did not change things either. I then re-verted back to the previous windows update but also this did not work and fix the issue.
Even after doing a system reset the discrete GPU is turned off. It does popup in the task manager and in Armory Crate but it's not active and all the applications on the PC use the integrated intel gpu which now fries my computer even when I am watching a video on YouTube.
I have to get this fixed though since my day job involves working in game engines with large heavy projects.
Anyways I hoped someone here would be able to help me and the sooner the better.
I will include
6 REPLIES 6
Roasiac
Falcon_ASUS
https://zentalk.asus.com/en/discussion/comment/240800#Comment_240800
@Roasiac
I have replied to you again, please check.
Sorry for my late reply but I have responded back to you.
Falcon_ASUS
Roasiac
https://zentalk.asus.com/en/discussion/comment/240891#Comment_240891
@Roasiac
Confirmed by the technical unit, the Ultimate exclusive display icon in Armory Crate has not disappeared.
Could you please provide the phenomena/videos of the problems encountered in the actual operation for confirmation?
