FX506LH TUF F15 No power
John67
Tuf F15 was working fine, tried to switch on next day & completely dead, Mains charger ok & tried hard reset, No power light, laptop is less than 2 years old & has had very little use. Definitely no liquid or impact damage, would have expected to last a bit longer. Is it viable to send for repair if motherboard.
Falcon_ASUS
@John67
If the laptop shows no indication lights when connected to the charger, we would suggest you bring back your laptop to our service center for further confirmation.
