Can’t Set Up Zen WiFi
Ksternberg54
My new AC3000 Zen WiFi system looks great. But I haven’t been able to link it to my FIOS Internet router. The ASUS router and the node are less than two feet from the Verizon router. I’m using the phone app and it can’t locate the Internet signal/system/etc. Both routers are attached to the WAN inputs.
Any suggestions before I need to return it?
Thanks.
Falcon_ASUS
Ksternberg54
Thanks.
@Ksternberg54
This is the "Phone Community".
If you have problems with router products, I would like to suggest you contact the local service center for help.
http://www.asus.com/support/CallUs#
