My laptop will not connect to the WiFi, how do I fix this?
kinmo
All of my other devices are connected to the internet but my ASUS laptop does not, the WiFi option isn’t even coming up, pls help
jzchen
Zen Master II
Go to the search and search for Device Manager.  Check for any "!" and clear them.
Falcon_ASUS
@kinmo
Please refer to the following FAQ for troubleshooting steps.
[Windows 11/10] Troubleshooting - Wireless Network (Wi-Fi) Issues
If no wireless network device appears in Device Manager and the issue persists after reinstalling the driver, it might be a hardware malfunction.
I would suggest you bring back your laptop to our service center for further confirmation.
