Battery
Mashego
Asus E410 celeron notebook, only working when it's connected to the charger, what could be the problem and how can I fix it. Please kindly assist
Falcon_ASUS
@Mashego
According to your description, it appears that the issue is due to battery aging or an abnormality, which is causing it to not function properly. We would recommend that you send it in for repair.
camilasaunder89
Rising Star I
Hi, As you said in the query that your laptop is charging only while connected to the battery then it seems that your battery needs to be replaced. Apart from this, try to clean the laptop files that are no longer required and try resetting the laptop.
ZenBot
Community Manager
Community Manager
