02-20-2024 06:07 AM
StudioBook H5600Q has a bug with battery saving functionality. When I set up to charge battery not more then 80% this functionality applies just for the main charger and do not work in case laptop charges with USB Type-C power delivery. I believe that this functionality should apply to any charge input.
02-28-2024 02:31 AM
Usually I am using connection to Samsung M8 monitor with PD 60W. Also, I tried the ASUS AC Adapter 100W(Model: A20-100P1A) and again even though I have 100% on the battery it continue to charge.
03-04-2024 06:34 PM
@sergii_cheliuk
Are you currently experiencing an issue where both using Samsung's PD and the adapter we provided result in charging up to 100% and cannot be capped at 80%?
We tested our own PD, and charging can be capped at 80%. In your current situation, we would recommend removing MyASUS and reinstalling it to confirm.
03-09-2024 12:52 PM
For now looks like everything is fine. I changed settings to charge up to 60% and than back to 80%. After this change battery saver works fine for type-c chargers.
