Battery bypass option on ASUS TUF Laptops?
Anna-Kin
Rising Star I
Battery or AC: Both
Model: TUF F 15 2022- FX507ZM
Frequency of occurrence: Always
Reset OS: Yes
Screenshot or video:
System: TUF F 15 2022- FX507ZM
Detailed description:
Is there a way to enable a Battery Bypass option on TUF Gaming laptops,
So that while gaming the laptop directly consumes power from the charger?
Because while gaming my battery drops down to 99% after 15 minutes of gaming and then the CPU gets locked at 25 Watts instead of 45 Watts which causes significant performance loss.
I checked using a Watt meter plugged into the 240 Watt charger, while gaming when the laptop is at 100% charge the total power consumption is 205 Watts and after 15 minutes of gaming the battery drops to 99%, and the power consumption gets locked at 160 Watts thus causing significant performance loss.
Honestly, ASUS at this point after spening $2000 on a laptop I have to do so much troubleshooting and experience poor performance, just take my laptop and give me a refund.
5 REPLIES 5
Falcon_ASUS
Anna-Kin
  1. Battery or AC: Both
  2. Model: TUF F 15 2022- FX507ZM
  3. Frequency of occurrence: Always
  4. Reset OS: Yes
  5. Screenshot or video:
  6. System: TUF F 15 2022- FX507ZM
@Anna-Kin
I have forwarded the information to the relevant department. We will keep you updated and your consideration will be very much appreciated.
Anna-Kin
Rising Star I
Falcon_ASUS
https://zentalk.asus.com/en/discussion/61762/battery-bypass-option-on-asus-tuf-laptops
@Anna-Kin
Any update from the relevant department?
Falcon_ASUS
Anna-Kin
https://zentalk.asus.com/en/discussion/comment/217423#Comment_217423
@Anna-Kin
it is confirmed that FX507ZM does not have this option.
Anna-Kin
Rising Star I
Falcon_ASUS
https://zentalk.asus.com/en/discussion/comment/217606#Comment_217606
@Anna-Kin
@Falcon_ASUS
Is it possible to enable it via a software update?
