I want someone to read my laptop battery report.
Anonymous
Not applicable
Hello,
I have a laptop, ASUS TUF F15 FX506HC. I've had it for a whole year.
I'm only charging the laptop to 80%, and when I use it, I keep it plugged in.
In general, I don't use the laptop a lot. There are no games on it.
But I noticed that the battery life is getting shorter quickly, even though I don't use the laptop much.
I want someone to read the battery report and give me some advice.
I'm so afraid. Please help me.
this is the report
https://drive.google.com/file/d/16oid8AkN842z9wc5OCbpW2Z81r7MH1nn/view?usp=sharing
Falcon_ASUS
@unknown056
If you have any concerns, it is recommended to use MyASUS to check the battery.
For detailed steps, please refer to the instructions in the FAQ below.
[Windows 11/10] Troubleshooting - Short Battery Life (Rapid Battery Drain)
Check the battery health
You can check the battery health status via the battery diagnosis tool in MyASUS app. Follow the steps below to check your device's battery health:
Note: If the battery health is bad, we recommend contacting ASUS Product Support for a battery replacement, in order to fully restore the battery's performance and capacity.
