Asus G14 cooling system and fan control
dmpotapenko1990
System: WIndows 10
Battery or AC: AC
Model: G401IU
Frequency of occurrence: Stable to repeat
Reset OS: yes
Screenshot or video:
Detailed description:
I want to discuss two of many problems here. They are relating to cooling system.
AC plugged in, Armoury Crate mode: Manual, close and open the laptop cover, system went to suspend and woke up - fans start pumping, fans change speed from expected to unexpected RPM. I found that other people have the same issue.
Armoury Crate "manual" fan curves are available when charger is plugged in only . Do I have a chance to see this functionality for "battery" mode? I think so, the best solution - migrate all this stuff to BIOS. Fan curves in bios - a great idea to support other OSs(e.g. linux based).
In addition, many laptops have option to disable discrete GPU in BIOS, I will hope to see this in futher BIOS releases
5 REPLIES 5
Blake_ASUS
Community Legend II
Hi there,
How about the temperature and RPM in Armoury Crate?
2400-2600 rpm is actually pretty low, as the fan can go up to 6000 rpm when really hard loading.
