Tuesday
Gday
With the EBM68, can the different SSID created be on a separate channel? or do they all share the same channel?
Tuesday
I'm afraid I am unclear what you are asking? With what I currently understand: Smart Connect is optional and you should be able to separate different SSIDs for each channel.
Tuesday
so, given SSID_1, SSID_2, SSID_3; potentially each with their own vlan,
can i set say, SSID_1 on 2.4Ghz only at channel 1 and SSID_2 on 2.4Ghz only at channel 6 ?
from what you say, it sounds like, yes?
Tuesday
Ahh, I meant SSID_1 for 2.4 GHz, SSID_2 for 5 GHz. I have no idea honestly whether it is capable of broadcasting 2 2.4 GHz SSIDs. I'm sorry. I hope a moderator has the answer you are looking for now that it is clear.
Tuesday - last edited Tuesday
ok thanks
i asked because my TP-Link deco xe75pro seems to struggle once i add 4 cameras to the existing 4 cameras, 20ish smartplugs/things plus laptops and phones (all up 45 devices)
however if i put those 4 extra cameras to a small travel router as wifi AP on a different 2.4ghz channel then it all works perfectly
i had hoped a pair of ebm68 could handle the workload vs buying more wifi ap for the other band
