AI mesh keeps switching between nodes
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-05-2025 09:33 AM
Within the last month my ASUS mesh network keeps switching my Apple products between the base (RT-AX86U Pro) and the node (RT-AX55) with multiple seconds of no connection in between. I notice this happening in one area of my house where I spend a lot of time. It may happen in other areas, Idk. Seems to be a recent issue.
Anyone else have this issue?
Can I change a setting to stop this behavior?
Everything has the most recent updates.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-06-2025 03:53 AM
It's probably best to look at the system log and see at what RSSI it is moving from one to the other. The setting is default to -70...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-06-2025 10:03 AM - edited 02-06-2025 10:38 AM
Here's a sample of the log. I replaced the actual MAC address of the iPhone with "iPhone MAC address".
How can I adjust the RSSI threshold for switching nodes?
Feb 5 09:06:50 rc_service: cfg_server 3270:notify_rc update_sta_binding;
Feb 5 09:06:56 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc iPhone MAC address, status: Successful (0), rssi:-75
Feb 5 09:12:46 bsd: bsd: Sending act Frame to iPhone MAC address with transition target eth6 ssid Device MAC address
Feb 5 09:12:46 bsd: bsd: BSS Transit Response: ifname=eth7, event=156, token=23, status=7, mac=00:00:00:00:00:00
Feb 5 09:12:46 bsd: bsd: BSS Transit Response: not for token b2
Feb 5 09:12:46 bsd: bsd: BSS Transit Response: ifname=eth7, event=156, token=24, status=7, mac=00:00:00:00:00:00
Feb 5 09:12:46 bsd: bsd: BSS Transit Response: not for token b3
Feb 5 09:12:46 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind iPhone MAC address, status: 0, reason: Previous authentication no longer valid (2), rssi:-81
Feb 5 09:12:46 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc iPhone MAC address, status: Successful (0), rssi:-59
Feb 5 09:13:06 bsd: bsd: Sending act Frame to iPhone MAC address with transition target eth7 ssid Device MAC address
Feb 5 09:13:06 bsd: bsd: BSS Transit Response: ifname=eth7, event=156, token=25, status=7, mac=00:00:00:00:00:00
Feb 5 09:13:06 bsd: bsd: BSS Transit Response: not for interface eth6
Feb 5 09:13:06 bsd: bsd: BSS Transit Response: ifname=eth7, event=156, token=26, status=7, mac=00:00:00:00:00:00
Feb 5 09:13:06 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind iPhone MAC address, status: 0, reason: Previous authentication no longer valid (2), rssi:-59
Feb 5 09:13:06 wlceventd: wlceventd_proc_event(685): eth7: Auth iPhone MAC address, status: Successful (0), rssi:0
Feb 5 09:13:06 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc iPhone MAC address, status: Successful (0), rssi:-81
Feb 5 09:13:06 wlceventd: wlceventd_proc_event(662): eth6: Disassoc iPhone MAC address, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Feb 5 09:20:03 acsd: acs_set_chspec: 0x1008 (8) for reason ACS_CSTIMER
Feb 5 09:28:59 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind Device MAC address, status: 0, reason: Group key update timeout (10), rssi:-64
Feb 5 09:29:00 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind Device MAC address, status: 0, reason: Group key update timeout (10), rssi:-64
Feb 5 09:29:04 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc Device MAC address, status: Successful (0), rssi:-65
Feb 5 09:29:56 wlceventd: wlceventd_proc_event(685): eth6: Auth iPhone MAC address, status: Successful (0), rssi:0
Feb 5 09:29:56 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc iPhone MAC address, status: Successful (0), rssi:-57
Feb 5 09:29:58 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind iPhone MAC address, status: 0, reason: Station requesting (re)association is not authenticated with responding station (9), rssi:-79
Feb 5 09:29:58 wlceventd: wlceventd_proc_event(662): eth7: Disassoc iPhone MAC address, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:-79
Feb 5 09:29:59 wlceventd: wlceventd_proc_event(685): eth7: Auth iPhone MAC address, status: Successful (0), rssi:0
Feb 5 09:29:59 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc iPhone MAC address, status: Successful (0), rssi:-79
Feb 5 09:29:59 wlceventd: wlceventd_proc_event(662): eth6: Disassoc iPhone MAC address, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Feb 5 09:48:29 acsd: acs_set_chspec: 0x1008 (8) for reason ACS_CSTIMER
Feb 5 09:54:59 bsd: bsd: Sending act Frame to iPhone MAC address with transition target eth6 ssid Device MAC address
Feb 5 09:54:59 roamast: [EXAP]Deauth old sta in 1 0: iPhone MAC address
Feb 5 09:54:59 roamast: eth7: disconnect weak signal strength station [iPhone MAC address]
Feb 5 09:54:59 bsd: bsd: BSS Transit Response: ifname=eth7, event=156, token=b0, status=1, mac=00:00:00:00:00:00
Feb 5 09:54:59 bsd: bsd: BSS Transit Response: not for token b6
Feb 5 09:54:59 bsd: bsd: BSS Transit Response: ifname=eth7, event=156, token=b1, status=1, mac=00:00:00:00:00:00
Feb 5 09:54:59 bsd: bsd: BSS Transit Response: not for token b7
Feb 5 09:55:00 roamast: eth7: remove client [iPhone MAC address] from monitor list
Feb 5 09:55:01 wlceventd: wlceventd_proc_event(662): eth7: Disassoc iPhone MAC address, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Feb 5 09:55:24 wlceventd: wlceventd_proc_event(685): eth7: Auth iPhone MAC address, status: Successful (0), rssi:0
Feb 5 09:55:24 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc iPhone MAC address, status: Successful (0), rssi:-79
Feb 5 09:55:40 roamast: [EXAP]Deauth old sta in 1 0: iPhone MAC address
Feb 5 09:55:40 roamast: eth7: disconnect weak signal strength station [iPhone MAC address]
Feb 5 09:55:40 roamast: eth7: remove client [iPhone MAC address] from monitor list
Feb 5 09:55:43 roamast: determine candidate node [7C:10:C9:DD:BB:D4](rssi: -64dbm) for client [iPhone MAC address](rssi: -81dbm from client)(rssi: -82dbm from ap) to roam
Feb 5 09:55:44 wlceventd: wlceventd_proc_event(662): eth7: Disassoc iPhone MAC address, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Feb 5 09:56:29 wlceventd: wlceventd_proc_event(685): eth7: Auth iPhone MAC address, status: Successful (0), rssi:0
Feb 5 09:56:29 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc iPhone MAC address, status: Successful (0), rssi:-57
Feb 5 10:16:56 acsd: acs_set_chspec: 0x1008 (8) for reason ACS_CSTIMER
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-06-2025 11:16 AM
It seems, (I am not an expert at reading the logs), that the device leaves one station due to poor signal but can not connect to the nearer station. I'm not sure which station is which, but I would delete the RT-AX55 from AiMesh, hard/factory reset it, and then add it back as an AiMesh node...
