EBM68 ssid channels
Oscaroo
Gday
With the EBM68, can the different SSID created be on a separate channel? or do they all share the same channel?
11 REPLIES 11
Well, one thing that isn't often mentioned is, you do not have to create an AiMesh.  AiMesh as you may already know means both router and node broadcast the same channel and bandwidth, so devices can hop between the two.  If you simply make the 2nd EBM68 an Access Point, not an AiMesh node, then 100% certain you can broadcast Channel x on one and Channel y on the other.  I was trying to determine if a single EBM68 can broadcast 2.4 GHz SSID_1 freq 1, and 2.4 GHz SSID_2 freq 2.  I guess that is how IoT/Guest Network work beside Main network, but I haven't any experience with the EBM68 model...
Hi @Oscaroo ,
we apologize for the delayed response due to the recent holiday.
You can set different channels for different SSIDs on your EBM68 router.
Assigning different channels to separate SSIDs can effectively reduce wireless signal interference and improve network stability.
Please refer to the FAQ below for instructions on how to change the wireless channel on your router. If you have any further questions, feel free to contact us. Thank you.
[Wireless Router] How to fix wireless Control Channel? | Official Support | ASUS Global
so ...Aureliannn_ASUS
can you please confirm that:
i can have ssid1 at 2.4,ghz on channel 2
and ssid2 at 2.4ghz at channel 8
and ssid3 at 5ghz any channel
right?
Musa_Khan
Yes, with the ASUS Expert WiFi EBM68, you can assign different SSIDs (network names) to each frequency band—2.4 GHz, 5 GHz-1, and 5 GHz-2. This allows you to manage your wireless networks more effectively by separating devices based on their compatibility and performance requirements. Access your router admin panel and from the navigation panel, go to Settings > Wireless > General. Disable Tri-Band Smart Connect. After disabling Smart Connect, you'll have the option to set individual SSIDs for each band
no no no
im talking channels not bands
i want 2.4ghz ssid1 on say channel 2
and 2.4ghz ssid2 on channel 10
