10-13-2023 01:57 AM
Hello guys,
I had fiber connection from another ISP without lag spikes. I am changed ISP with better download/upload 1000/500mb broadband. Now i have in games like Fifa every 3 minutes lag spikes on PS5. I dont know where could be problem with my router AX3000v2, or could be problem on server side.
First ISP had static IP adress connection mode, new ISP has automatic IP.
Does anybody help me with this issue?
Thanks, sorry for my english
11-02-2023 11:16 PM
Hi @kazoo9 ,
based on your issue, may I ask have you make sure that the router firmware is at the latest version?
May I ask have you check the QoS setting?
Whether you're using wired or wireless connection?
Try connect your PS5 directly to the router via ethernet cable to see if the issue resolve.
Have you contact your ISP to confirm the issue? Maybe they will recommend specific setting for you.
