10-30-2021
12:10 PM
- last edited on
01-16-2024
04:17 PM
by
ZenBot
11-01-2021 07:59 PM
11-01-2021 09:54 PM
GabrielePorcuzAfter flashing of new bios firmware to laptop, we must do to load default settings in bios.Good evening.
I'm the owner of a Zenbook 14 UM425 with a Ryzen 7 4700U. Last week i installed windows 11 and the update of the bios and since then the fans started to work improperly, revving up for no specific reason. They even work when the computer is in state of suspension. For three times in a week i found the pc with the battery completely dead after i suspended it with about 30% of charge remaining. The last time it happened it was in his case in state of suspension for like 15 minutes, and when i took it out of the case i found out it was litterally melting... before the update i had never noticed such things... The worst part is that yesterday i set the hibernation whenever i close the lid so that the fans should not start to work (since the pc is basically turned off) and today it happened again... I replaced the pc iin his cover with about 25 % of the battery and 2 hours later, when i tried to turn it on the battery was dead.. What should i do? i'm so worried because the pc is only 4 months old and before the updates it never had such problems
Problem with Zenbook 14 fans/battery after win 11/bios update
11-04-2021 12:19 PM
Blake_ASUSHello Gabriele,
Can you enter BIOS and load default setting again?
And if the problem continues, would you mind to roll back to Win10 first to see if everything goes back to normal?
RAJU.MSC.MATHEMATICSGood evening, thanks for your answer.After flashing of new bios firmware to laptop, we must do to load default settings in bios.
11-04-2021 07:21 PM
