Cell Standby battery drain
Salvatore
i'm experiencing seriuos issue about battery, it's being constantly drained by cell standby with abnormal values. It's actually draining more than the display, that's unacceptable.
Can you please provide a fix/solution ?
Zenfone 8 - hardware and software details attached.
123 REPLIES 123
Chris1
Rising Star II
I second this.
I have the same behavior, even under very good coverage.
CH_ASUS
Community Legend II
Salvatore
In the past 18 hours, you've 18% of drain by standby.
Another 9hours with AOD active.
While I wont rule out any issues, it does not sound as bad as you make it out to be?
In either way, to figure out your specific device drain - we need to log the device in order to know more - whether or not the standby is within expectations or not.
@Anders_ASUS can assist in PM with logging procedure.
Salvatore
@CH_ASUS almost 20% of drain for cell stanby within 24h is not normal for sure. I come from ZenFone 6 and it never happened in 2 years. I dont' get the point about AOD, is it somehow connected to the cell standby drain ?
Chris1
Rising Star II
Maybe it's just a matter of presentation.
After 2,5 days since a full charge, 3,5h SOT, 1,75h of Spotify, 0,5h of Waze (quite a very light use, as i have 2 phones), i think that after all, standby "drain" is very acceptable.
Especially as the phone seems very sensitive to the networks (while at home / work i have very good coverage, i often go to remote aeras).
