Battery draining issue and screen gesture issue
My phone in on Version WW-16.2017.2009.087 . I am battery draining issue without doing anything, like if i keep my phone at 100% at night in the morning it is going down to 80% ,and no data available for battery consumption.
and second problem is double tap gesture is not working everytime.
Comments
Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Please follow below steps may improve battery backup:
1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
2. Adjust sleep time and brightness (Settings > Display)
3. Boost memory when you see memory consumption is high with no app running,
4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
Sis u tried formatting device, this may be due to software / bugs issue. Try formatting if that can help or else u need to visit SC for that
