Fingerprint and silent mode vibration bugs on Zenfone Max Pro M1
Incandenza
I'd like to point out two things I consider as bugs on Android 10 builds for Zenfone Max Pro M1:
1) When the phone is unlocked using fingerprint, it vibrates. But when the unlocking fails, it vibrates too. This is a dumb implementation. It's better to keep things as in Android 9: sound for successful unlocking, vibration when unlocking fails.
2) Vibration when we activate silent mode is stronger than vibration when vibrate mode is activated. This is counterintuitive. The phone should vibrate more when we activate vibrate mode, and less (or even don't vibrate at all) when we activate silent mode.
15 REPLIES 15
dibyarupprk2011
Rising Star II
Incandenza
1. Upon wrong fingerprint failing you'll get two haptic feedback and succesful fingerprint you'll get single haptic feedback, it's okay as pixel devices too has this ..
2. Ya..this is an issue from the very 1st build of Android 10 for Max Pro M1, switching silent mode gives more haptic feedback than switching the vibration mode..lol
@Christine_ASUS
Christine_ASUS
Community Legend II
Hi Incandenza & dibyarupprk2011
Thank you for your asking. Please clarify the issue to avoid misunderstanding in the conversation. Do you mean the vibration haptic strength of touch feedback is different, and in "Silent Mode" is stronger than in "Vibration Mode"? I just tested the touch feedback in three mode, "Silent Mode" "Vibration Mode" "Sound Mode", and I can not recognize the strength difference.
sujanjsr0
Rising Star II
Is it new feature in Android 10 to vibrate while unlocking with fingerprint?
But i think it will effect our battery backup
Christine_ASUS
Community Legend II
Hi sujanjsr0
Yes. It is the normal behavior of Andriod 10 ASOP system. Sorry for any inconvenience it may caused.
