WIFI & BLUEOTOTH ERROR
SAYA MENGGUNAKAN DEVICES ASUS ZENFONE MAX 3 ZC520TL, MENGAPA WIFI, BLUEOTOTH, DAN HOTSPOT SELULER TIDAK BISA MENYALA DAN TIDAK BERFUNGSI, BAHKAN PADA SAAT MODE AMAN PUN TETAP TIDAK BERFUNGSI, APA ADA SOLUSI SEBELUM SAYA MEMBAWANYA KE SERVICE CENTER ?
THANK YOU !!
Falcon_ASUS
jeremiahnicolaas002
THANK YOU !!
@jeremiahnicolaas002
If the problem still exists in safe mode,  I would like to suggest you to bring back your mobile to our service center.
http://www.asus.com/support/Service-Center-All-Countries/
Also you can contact the local service center for help. The following is the contact information:
http://www.asus.com/support/CallUs#
