how to update firmware
Mdzakiey
i am new user asus , how to want update firmware asus zenfone max 3?
Christine_ASUS
Community Legend II
Hi Mdzakiey
Thank you for your asking. To update the system, you may try Auto Update or Manual Update.
1. Auto Update (Easier Way)
Settings>System>System update
*Tap the 3 dots on the top row of "System update">Auto-update settings, for related settings
2. Manual Update (Normally be used in cross-Android firmware update or rooted/unlocked device)
Download the firmware file into the root directory, aka the outermost place, of the internal storage>Reboot>Tap the "system update" notification
*To perform cross-Android firmware update, please backup the device data first.
#[Zenfone] How to update firmware on my phone?
https://www.asus.com/support/FAQ/1009748/
#ZenFone3 Max (ZC520TL) Firmware Spot
https://www.asus.com/supportonly/ZenFone3%20Max%20(ZC520TL)/HelpDesk_BIOS/
However, which firmware version should I choose?
Each firmware version will optimize the system stability from the previous firmware version. You can upgrade to the latest firmware version in your current Android first.
Boi_erh
Software update not working
Christine_ASUS
Community Legend II
Hi Boi erh
What do you mean "software update"? Do you want to update the firmware system? If so, please provide me
1. Model Name: Settings>System>About phone
Refer to the link below to check the model name by model no. in the link
[Phone] How to find and recognize the ZenFone model name? | Official Support | ASUS Global2. Your current firmware version
Settings>System>About Phone>Software information
