Update failed
MONSTER
In Zenfone max pro M2 from past 5-6
update get failed. Software update is available pops up in notification bar. But every time it downloads and failed
After done all the things it shows up with popup and says your device is reverted to It's original configuration
56 REPLIES 56
MONSTER
MONSTER
https://zentalk.asus.com/en/discussion/comment/116171#Comment_116171
I used downgrade for pie and its complete now.
Now build number is PKQ1.WW_Phone-16.2017.1912.072-20191125
MONSTER
Anandu
https://zentalk.asus.com/en/discussion/comment/116165#Comment_116165
https://www.asus.com/support/FAQ/1042349
https://www.asus.com/in/Phone/Zenfone-Max-Pro-M2-ZB630KL/HelpDesk_BIOS/
Try this. Instructions above. Follow correctly. Also available in the website link above.
https://dlcdnets.asus.com/pub/ASUS/ZenFone/ZB631KL/UL-ASUS_X01BD-WW-16.2017.1912.072.999-user.zip
Once this is done try checking update.
(this is actually a downgrade firmware target to 72version, but this may work.)
It works 😊
veeharish2005
Zen Master I
MONSTER
https://zentalk.asus.com/en/discussion/comment/116168#Comment_116168
It works 😊
Go to settings and check for software update. There will be a software update. Download it and see if it installs successfully.
MONSTER
veeharish2005
https://zentalk.asus.com/en/discussion/comment/116183#Comment_116183
There is nothing
Yachendra
Rising Star II
MONSTER
https://zentalk.asus.com/en/discussion/comment/116189#Comment_116189
There is nothing
You may try after some time or days. Available update might pop out.
If not, download the firmware file and update manually.
