System Accessing Camera without any need or reason.
mauvin11
Rising Star II
The system is accessing phone camera every 2-3 minutes without any need or reason. I thought it was an third party app so I revoked access to all apps. It turned out it was system itself. I had some suspicions so installed an access monitor and it turned out to be true.
Looks Fishy, Should I worry about privacy?
1. My face unlock feature is turned off
2. Auto Brightness is turned off
26 REPLIES 26
Mayukh
mauvin11
The "Smart screen on" feature uses the camera from time to time to check whether the user is looking at the screen or not. That's why the system is using the camera, and the SafeDot is keeping the log. Just turn off the feature and you are good to go. And no need to worry about this, you can keep this on if you want.
To turn off = Settings-> Display-> Advanced-> Smart screen on (Turn this off if you want to)
I don't know why on earth are these moderators for😒
abhaykrishnan02
Zen Master I
Mayukh
https://zentalk.asus.com/en/discussion/49058/system-accessing-camera-without-any-need-or-reason
Its already off in my device.
mauvin11
Rising Star II
Mayukh
Thank You so much! It was indeed smart screen. I forgot this feature existed. I was really freaked out by the camera issue. I was about to put tape on my device. Yes. The mods as well as the developers are useless!
mauvin11
Rising Star II
abhaykrishnan02
https://zentalk.asus.com/en/discussion/comment/172941#Comment_172941
Try turning of Auto Brightness and Face Unlock!
Falcon_ASUS
mauvin11
@mauvin11
Thanks for your patience. Like information provided by others. It has been confirmed that if it is "Smart screen on", the camera will be turned on regularly to detect and determine whether there is a human face in front of the screen as described , please don't worry.
